Hi!!! My name is Vladislav. I live in Russia , recently purchased a Golf-4 with the engine 1.4 BCA and mileage 150000км,I don't know, real or not,With Germany brought 2008-owned 96 000 km , friends say that you have a very high mileage roll . In General, I have a problem with switching gears , bad 1 is enabled and 2 , how can I solve the problem? It is worth chip tuning 1.4 or not worth it!!!What pour oil into the engine which viscosity?Lew Shell 5-30! I can't disperse more than 160 km,did not go further , after 160 begins поттормаживать,what might be the cause?I I understand that 1.4 is not rushing,but not to this degree)at the cold goes well ,as warm pulls no,why???Sell there is no sense machine is good,and find another in excellent condition in Russia is not real! what to bring to mind...
Helfen, mit Golf 4 1.4 bei der Erwärmung zieht schlecht
- [Antrieb]
- Владислав
Hi Vladislav, wellcome to our Forum
I'm not quite shure where your problem is, because you dicribeed it a little bit curious.
Would you please try again to discribe the problem with your gearbox?Regarding your question whith chip tuning; for your engine it would not be worth the money to spend. In maximum it will bring 5-10HP not more!
The oil, you suggest will work for your engine.The problem with the maximum speed I also don't understand, because there is an russian word in your thread and I'm not able to read and understand.
Der erste und der zweite übertragung eng mit Aufwand eingesteckt werden,ein Gefühl, als ob etwas sträubt sich
Vladislav, if it possible try to wite in english.
This translator is horrible to understand. Can you please tell us what kind of gearbox you have? There must be an Identification code like DUW, it is located underneath the gearbox. So if you lift up your car and remove the panel you will see an plain region where the code is graven.Fact is, the DUW gearbox has a problem with loosen rivets inside, at the differential.
Thanks,I understand! Today check room
found the room DUW 0208 !!!!
Wie viel kostet in Deutschland der Motor 1.4 ? -
found the room DUW
So, it seems you have the problem with this loosen rivets, alsoThe costs for motors depends how high the milage is. You can check this on ebay.de.
Ok, it seems that you found the fault on your engine. Also the problem with your gearbox seems to be located.
Depending on your mechanical skills I suggest to buy a damaged car (maybe with an stronger engine) and switch the engine and gearbox
Hi All! What oil pour 5-30 or 5-40????mileage 150000км
5-40 should be suitable
No, don't think so, because this is only the mechanic for gearshifting.
