Good day fellow dubbers
I've got some electrical issues with my GTI 16v (KR) CE1
First, the idle does not work, the idle valve is checked to be working, and the 244 module (Idle control unit) is also checked to be working as it should
so my problem is somewhere between those.
so, my question to you are, does anyone have the wiring schemes over the idle circuit for a 1988 GTI 16v KR?
and another electrical problem, when i flick the lightswitch, the speedometer goes bananas, the RPM counter dies in an instand, and oil light and chargelamp comes on. and the MFA stops working. when i turn of the lightswitch again, everything goes back to normal
the ignition switch is new btw. so are the fusebox
and a thrid thing. what relays should i have?
i've got the relay for:
Load Reduction (18)
Fuelpump (67)
Blinkers
wipers
and 1 more i don't remember what is
Help is much appreciated
Regards
Dan
